Call manager 6.1.1
Jul 2nd, 2008
I have a cisco call manager 6.1.1 i have this call manager connected to a switch and then i have an ip phone connected to the same switch. hence the phones and call manager are on the same lan. i am not able to get the phones registered with the call manager. im using the web interface. please let me know how i can get the phone (cisco ip 7940) registered with the call manager
Overall Rating: 5 (1 ratings)
Jaime Valencia Wed, 07/02/2008 - 12:26
have you already configured the phone in CCM??
have you pointed the phone to use CCM as the TFTP, using DHCP or by manual config?
what does the phone says??
javalenc
if this helps, please rate
mohammedanasshaikh Wed, 07/02/2008 - 12:29
i added the phone using the web interface i filled in all the required fields, the phone gets an ip address when i reboot it, but when i go to the call manager web interface it shows that no ip address of a phone or no phone is detected
mohammedanasshaikh Wed, 07/02/2008 - 12:30
I am not sure if i have done the right steps, can you please tell me how i can tell the phone to use the CCM as the tftp server, i kno i can manually do tat but i tried it , and it gives me the same problem the call manager doesnt seem to detect that the phone is present.
Jaime Valencia Wed, 07/02/2008 - 12:34
are the TFTP services running??
is CCM running?
do you have the node license??
do you have the feature license??
if using DHCP set option 150, if manually then just type in the phone the ip of CCM as TFTP
javalenc
mohammedanasshaikh Thu, 07/03/2008 - 10:08
I got a new license for it and it started working, Thanks.
However i jus entered the setting manually into the phones through the CCM web interface. Could you please tell me how i can configure the calll manager using the command line. how do i make the ccm a DHCP server so tat it assigns the iP address itself to the phones.
Jaime Valencia Thu, 07/03/2008 - 11:04
ok, glad to hear that.
this new version allows you to configure stuff but without the right license it won't work at all.
you need to understand that linux appliance CLI is only for certain things, and configuring the CUCM is not one of those. All needs to be done thru the CCMAdmin.
go to this link:
Maintain and Operate Guides
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_maintenance_guides_list.html
download the PDF that matches your version, the name is:
Cisco Unified Communications Manager Administration Guide, Release 6.??
download the one for your version
once you have the link open it and browse under the system configuration until you see:
DHCP Server Configuration and
DHCP Subnet Configuration
Those will give you all the config steps, if you go to the CUCM menus and try them without looking at the guide you will see that they're pretty straightforward
javalenc
