CallManager 4.13 Subscriber SQL Issue after adding to cluster
Answered Question
Jul 2nd, 2008
I have a customer with 1 CM Pub and Sub on version 4.1(3). I added a second subscriber with the same exact version and SR patches. Problem I'm running into is in SQL Enterprise Manager, the replication fails and it complains of "COuld not find stored procedure "IsChangeNotifyReady"". I looked at the Pub and the stored procedure exists. Any ideas? Database names are the original CCM0300 across the board.
Correct Answer by rob.huffman about 8 years 6 months ago
Hi Jonathan,
Have a look at these good docs;
Reestablishing a Broken CallManager Cluster SQL Subscription with Cisco CallManager
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801d11a6.shtml
Using DBLHelper to Reestablish a Broken Cisco CallManager Cluster SQL Subscription
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801e7ddf.shtml
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
rob.huffman Wed, 07/02/2008 - 18:08
Hi Jonathan,
Hope this helps!
Rob
SAN J Wed, 07/02/2008 - 18:44
Yeah, saw the doc after I posted this. I reinitialized the db and restarted the risc data collector and that did the trick. thanks for the response...
