WDS - Client Configuration Help
Jul 2nd, 2008
Hi All,
I have many ap1252ap's, I have configured WDS on the one ap and it authenticate to itself OK - to the locally configured radius server.
state = wlccp_ap_st_registered
The problem is that I do not know where to go from here.
I have followed the docs (Fast Roaming, WDS) but I cannot get very far, in fact I do not think that my clients are even attempting to authenticate with my AP. I have modified the following taken from the sraom doc,
AP# configure terminal
AP(config)# dot11 ssid fastroam
AP(config-ssid)# authentication network-eap eap_methods
SSID CONFIG WARNING: [fastroam]: If radio clients are using EAP-FAST, AUTH OPEN with EAP should also be configured.
AP(config-ssid)# authentication key-management cckm
AP(config-ssid)# exit
AP(config)# interface dot11radio0
AP(config-if)# encryption mode ciphers ckip-cmic
AP(config-if)# ssid fastroam
AP(config-if)# exit
AP(config)# end
But something is still not right or missing. I have added users (or at least I think I have from an authentication point of view) with the username and password as the MAC of the clients to the local radius server, using command
ap(config-radsrv)#user xxx password xxx
But i do not understand how this links in with the client, basically how do I configure a client to attach using cckm, where do i put in a username and password for the network profile, if i pick leap, then I am prompted for the username/password, but what username/password is this, is it the username/password entered with
Any help would be much appreciated.
ahkal_cisco Wed, 07/09/2008 - 13:55
Thankyou for reading my Post, I have managed to work out how to configure my WDS with usernames and passwords, if anybody else is interested, this is what I did.
dot11 ssid fastroam
authentication open eap method_clients
authentication network-eap method_clients
authentication key-management wpa
(method_client is basically a list pointing with IP of server providing WDS/Radius)
Interface dot11radio 0
ssid fastroam
encryption mode ciphers tkip
no shut
To configure user/passowords
conf t
radius local-server
user testing password testing123
then on client
configure LEAP
user: testing
password: testing123
the client should now authenticate to AP/WDS.
The only thing I have not worked out yet is how to configure a backup WDS. nor do I quite understand which of the authentication methods the client is using when it succesfully connects.
Please can you advise: When you have a username/password on the radius server, does it mean that any/or all clients can use the same username/password.
or will the radius server detect that the login is already is use and prevent another attempt. reason behind my question is that if the username/password gets into the wrong hands.
Thanks and Regards
Trending Topics - Security & Network
