PIX LAN Base Failover
Jul 2nd, 2008
I have pix 525 with 8.x IOS. earlier i have the serial base failover it was working fine, but when i try to configure this pair with lan to lan failover. I m not able to configure this.
I tried with cross cable used for lan to lan failover and also try with making sepearte vlan for lan base failover cable.
First i configure the primary firewall with the below commands
failover
failover lan unit primary
failover lan interface failover Ethernet2
failover replication http
failover link state Ethernet3
failover interface ip failover 192.168.96.1 255.255.255.0 standby 192.168.96.2
failover interface ip state 192.168.97.1 255.255.255.0 standby 192.168.97.2
When i paste these commands i got this messsage
At that time secondary firewall was not power up.
Then I power up the secondary firewall and configure the following commands and also no shut the stateful and lan interfaces
pixfirewall(config-if)# failover lan unit secondary
pixfirewall(config)# failover lan interface failover Ethernet2
INFO: Non-failover interface config is cleared on Ethernet2 and its sub-interfaces
pixfirewall(config)# failover replication http
pixfirewall(config)# failover link state Ethernet3
INFO: Non-failover interface config is cleared on Ethernet3 and its sub-interfaces
pixfirewall(config)# failover interface ip failover 192.168.96.2 255.255.255.0$
pixfirewall(config)# failover interface ip state 192.168.97.2 255.255.255.0 st$
pixfirewall(config)# .
No Response from Mate
a.alekseev Wed, 07/02/2008 - 14:42
on the second
no failover
failover
wasiimcisco Wed, 07/02/2008 - 20:48
my firewall inside interfaces are connected with switch, i made a vlan in that switch and put lan failover cables there. Will that fine. Secondly i tried with cross cable as lan base failover, is that right or switch must require for it.
i will put the commands u given to me, and ten get back to u with the restul.
thanks for the reply.
wasiimcisco Thu, 07/03/2008 - 06:37
i tried but still the problem is there
pixfirewall(config)# failover lan unit secondary
========================== NOTICE ===========================
This platform is licensed as a secondary failover only unit.
This platform will reboot at 24 hours intervals in its
current state.
Switching to Active
Pleaes help me out how to solve this problem.
a.alekseev Thu, 07/03/2008 - 06:52
do you understand the difference?
and
failover interface ip failover 192.168.96.2 255.255.255.0 standby 192.168.96.1
failover interface ip state 192.168.97.2 255.255.255.0 standby 192.168.97.1
do on the second
no failover
failover
