IP Faxing
thisisshanky Wed, 07/02/2008 - 21:36
This is nto a very scalable solution. If Unity is loaded with users (voice mail subscribers, call handlers, autoattendants,) and you use store and forward T37 faxing on the same server, this could increase the cpu utilization on the Unity server as the number of fax sessions going through the box increases. Its also recommended that you use a router with good ram (atleast 512 to 1 gb of ram) as tiff images can chew up a lot of memory.
I d recommend to go purchase something like Xmedius IP fax that uses t38 faxing.
