CSS - Load balancing to Microsoft 2008 Sharepoint Application
Jul 2nd, 2008
We are tring to load balance using the CSS 11503 to two Servers running Microsoft Sharepoint 2008. Everything is working fine as far as load balancing is cocerned. But what we want is if the Microsoft Sharepoint 2008 Application is down one one server then we do not want any request for this application to be sent to this server. What sort of keepalive should we be using, because TCP port 80 is still up and responds when the Microsoft Sharepoint 2008 Application is down on this server.
I do not know much about how Microsoft Sharepoint 2008 Application interfaces / interacts with IIS and port 80, etc.
Any suggestions?
astanislaus Wed, 07/02/2008 - 23:56
Partial Config:
service FRED30
ip address x.x.x..100
protocol tcp
port 80
redundant-index 3
keepalive port 80
keepalive type http
active
service FRED31
ip address x.x.x.101
protocol tcp
port 80
redundant-index 4
keepalive port 80
keepalive type http
active
When we do the above where we have
"keepalive type http"
and then do a show keepalive we get the State as DOWN - why? But if we take out the keepalive type http command from the above services then we don't see the state as DOWN.
But even when it says DOWN we can still connect to port 80 without problem.
CSS# sh keepalive AUTO_FRED30
Name: AUTO_FRED30 Index: 7 State: Down
Description: Auto generated for service for FRED30
Address: x.x.x.100 Port: 80
Type: HTTP:HEAD:/
Keepalive Error: General failure
Frequency: 5
Max Failures: 3
Retry Frequency: 5
Dependent Services:
FRED30
sh keepalive FRED31
Name: AUTO_FRED31 Index: 9 State: Down
Description: Auto generated for service FRED31
Addresess: x.x.x.101 Port: 80
Type: HTTP:HEAD:/
Frequency: 5
Max Failures: 3
Retry Frequency: 5
Dependent Services:
FRED31
