Can any one help Reg:Dynagen ?
Jul 2nd, 2008
Dear Experts,
Can any one help me how to use Dynagen ?
I have all ready installed the software please help me to start the Dynagen...
Kiran
dhananjoy chowdhury Wed, 07/02/2008 - 23:56
Hi Kiran,
here is the link for the steps:-
http://ardenpackeer.com/study-tips/how-to-set-up-a-basic-dynamips-lab-using-dynagen-part-1/
But I would suggest to use GNS3, it is very easy to setup and to work in the GUI interface as compared to the Dynamips.
GNS3 also uses dynamis in the background but the GUI interface makes it easier to work.
www.gns3.net
HOpe this helps.
dhananjoy
