error detected on gi1/9
Jul 3rd, 2008
Hi folks,
As per the logs created I found the following errors on the port gi1/9
ERROR "link-flap error detected on Gi1/11, putting Gi1/11 in err-disable state"
Jul 2 16:25:15 gmt: %PM-SP-4-ERR_DISABLE: link-flap error detected on Gi1/9, putting Gi1/9 in err-disable state
Jul 2 16:25:15 gmt: %PM-SP-STDBY-4-ERR_DISABLE: link-flap error detected on Gi1/9, putting Gi1/9 in err-disable state
Jul 2 16:47:55 gmt: %PM-SP-4-ERR_DISABLE: link-flap error detected on Gi1/8, putting Gi1/8 in err-disable state
Jul 2 16:47:55 gmt: %PM-SP-STDBY-4-ERR_DISABLE: link-flap error detected on Gi1/8, putting Gi1/8 in err-disable state
Naidu.
ilnaiduccna Thu, 07/03/2008 - 03:25
Hi Dananjoy,
Thanks for your early reply.
Present I am at remote location need to coordinate with on site persons.
As you told I understood about cable, duplex except gbic converter.
Can you tell brief about gbic converter?
Naidu.
