CCM Backup Problem
Jul 3rd, 2008
I have installed a new CCM 6.0.1 server. While I'm doing th first backup, when it tries to do a backup from subscriber MOH server, I have the following error:
Feature : CCM
Component : MOH
Time Completed: 2008-07-03-12-03-08
Result Code : 106
Result String : ERROR
MOH: ready for backup
Starting MOH backup
MOH: Backup failed (255)
----> BEGIN Standard Output
----> END Standard Output
----> BEGIN Standard Error
Pseudo-terminal will not be allocated because stdin is not a terminal.
Read from remote host ccm: Connection timed out
----> END Standard Error
I'm not sure what the problem is, so any help would be apreciated.
ivillegas Wed, 07/09/2008 - 13:41
Perform the following steps:
1. Log into your server with remote admin account and go to /home/drfuser/.ssh
2. cp known_hosts known_hosts.keep (this is to keep a copy of the file with new-key)
3. Reboot your server
4. Log into your server again and go to /home/drfuser/.ssh
5. cp known_hosts.keep known_hosts (this is to overwrite the file to put your new-key back)
6. DRF should now work
gogasca Wed, 07/09/2008 - 20:25
You need root access so basically a TAC case needs to be open
You already reboot | restarted DRF services?
