Upgrade CUPS from 1.0.3 to 6.0.3 unknown Error
Jul 3rd, 2008
Dear all,
I am tring to upgrade CUPS from 1.0.3 to 6.0.3 by using this patch cisco-ipt-k9-patch6.0.3.1000-12.tar.gz
I burned the patch in a DVD and when reaching the "Apply additinal release" window i got three options to install the patch which are:
2) FTP
3) Local
i choosed local which is the DVD option as mentioned in the cisco document and i got the following error:
" No Valid patches found on DVD "
but i can see that setup didnt' even go to the DVD to check the patch
Any bodu can help me???
Error message is attched
Kindly advice.
Jaime Valencia Thu, 07/03/2008 - 03:52
the name of the file is not correct, it should be:
if this helps, please rate
eemara949 Sat, 07/05/2008 - 21:42
Dear Mr. Valencia
I changed the file name and trying to upgrade from the CUPS Operating System Administration Webpage through FTP and i got the following error
The directory was located and searched but no valid options or upgrades were available. Note, a machine cannot be downgraded so option and upgrade files for previous releases were ignored. "
Kindly help.
eemara949 Sun, 07/06/2008 - 01:07
Dear Mr. Java,
I reached to the final point of upgrading and i got the error as attached in the screenshot
I attached the logs file as well.
Please help,
Jaime Valencia Sun, 07/06/2008 - 10:24
there are a lot more logs needed to tell the exact cause of the error. a couple of things could cause the error:
not enough space in HDD or a server not compatible with that presence version. did you verified your server can support CUPS 6??
