Configuartion consistency tool
cisco_lad2004
Level 5
Level 5
Hi all
I am after a good tool which can fetch configs from network, compare it to a base template and report any deviations.
I use rancid today to get differential changes, but this does not tell me if the changes are in line with the base template.
Any recommendation woudl be great !
TIA
Sam
andrew.burns
Level 7
Level 7
CiscoWorks RME has this capability (it works, but is somewhat labour-intensive and obviously is Cisco-centric)
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps2073/prod_white_paper0900aecd8068cc98.pdf
A much better tool is NCM (Network Compliance Manager) which is multi-vendor, easy to use, produces excellent reports but is somewhat expensive.
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6911/ps6923/product_data_sheet0900aecd8070f093.html
Andrew.
Cheers Andrew
I wonder if it is worth getting this scripted, or use RANCID but diff new config files Vs a static template.
Sam
Not really IMHO. Depending on your clients regulatory requirements you may want to investigate a product that Cisco resells from HP (they were formerly known as a stand alone company Opsware) called NAS.
