VPN ip flow in only one direction
Answered Question
Jul 3rd, 2008
I have a Site-to-Site VPN that works finein one direction, remote to center, i.e. it goes up, using VNC to connect from remote to central or viceversa works, on the reverse side (central to remote) doesn't and ping doesn't in both ways.
IMHO, there should be something missing on central site, because if I ping from central lan to remote lan, or viceversa central asa says:
No translation group found for icmp src inside:IP_ON_CENTRAL_LAN dst inside:IP_ON_REMOTE_LAN (type 8, code 0)
Remote is on nat0, i.e. I have
access-list inside_nat0_outbound extended permit ip LocalLAN 255.255.255.0 RemoteLAN 255.255.255.0
access-list inside_nat0_outbound extended permit icmp LocalLAN 255.255.255.0 RemoteLAN 255.255.255.0
access-list outside_1_cryptomap extended permit ip LocalLAN 255.255.255.0 RemoteLAN 255.255.255.0
access-list outside_1_cryptomap extended permit icmp LocalLAN 255.255.255.0 RemoteLAN 255.255.255.0
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 0 access-list inside_nat0_outbound outside
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set peer REMOTE_PUBLIC_IP
On the remote (a pix 501), I have:
access-list inside_outbound_nat0_acl permit ip LanRemote 255.255.255.0 LanCentral 255.255.255.0
access-list inside_outbound_nat0_acl permit icmp LanRemote 255.255.255.0 LanCentral 255.255.255.0
access-list outside_cryptomap_20 permit ip LanRemote 255.255.255.0 LanCentral 255.255.255.0
access-list outside_cryptomap_20 permit icmp LanRemote 255.255.255.0 LanCentral 255.255.255.0
nat (inside) 0 access-list inside_outbound_nat0_acl
crypto map outside_map 20 ipsec-isakmp
crypto map outside_map 20 match address outside_cryptomap_20
crypto map outside_map 20 set peer CENTRAL_PUBLIC_IP
crypto map outside_map 20 set transform-set ESP-3DES-MD5
crypto map outside_map interface outside
What am I doing wrong?
Correct Answer by a.alekseev about 8 years 11 months ago
something is wrong with routing on central
Overall Rating: 5 (1 ratings)
Correct Answer
a.alekseev Thu, 07/03/2008 - 11:37
  • Gold, 750 points or more
sandman42 Fri, 07/04/2008 - 01:28
What's wrong is that I'm a chump!!!!
I forgot to include a reverse route command, i.e. before it was
crypto map outside_map 1 set transform-set ESP-3DES-MD5
crypto map outside_map 1 set reverse-route
now it's
I know it's obvious for you, but I've replied just to help somebody else not forgetting this one.
Thanks for your collaboration
