Solaris for MGC
Jul 3rd, 2008
Hello people,
I am using Solaris for PGW2200
I have inserted a DVD in the SUN Netra 210 with 2 folders and 3 files:
- File install.sh
- File uninstall.sh
- File admin
I want to run the uninstall.sh, but when I log in the system with ROOT user and when I position the folders in:
cd /cdrom and when I make ls -a I only can see ". .." 3 points.
I am not able to see the 3 files (install.sh, uninstall.sh and admin)... How can I do for run the uninistall.sh?
With best regards and thanks.
Urban_Nights Mon, 07/07/2008 - 07:20
Solved:
most likely your /bin/sparc/uninstall.sh is not set for executable.
check to see if the file has execution bit turned on by running *ls -l /bin/sparc/uninstall.sh*
if not, run *chmod u+x /bin/sparc/uninstall.sh* to set the exec bit for the user.
also, note that if /bin/sparc is not in your path, you should execute the file like *./uninstall.sh* within the /bin/sparc directory or use the full path.
