uninstall.sh
Jul 3rd, 2008
Hello people,
I am having a problem.
I want to uninstall an application in Solaris which name is MGC 9.7 Sparc.
I have the uninstall.sh file in the dir /bin/sparc and when I try to run uninstall.sh it shows.... cannot execute.
./uninstall.sh cannot execute
What could be the problem?
Thank you and regards,
Urban.
Overall Rating: 1 (1 ratings)
Urban_Nights Wed, 07/09/2008 - 08:15
The problem was with file itself.
most likely your /bin/sparc/uninstall.sh is not set for executable.
check to see if the file has execution bit turned on by running *ls -l /bin/sparc/uninstall.sh*
if not, run *chmod u+x /bin/sparc/uninstall.sh* to set the exec bit for the user.
also, note that if /bin/sparc is not in your path, you should execute the file like *./uninstall.sh* within the /bin/sparc directory or use the full path.
