no display for 7914 expansion module
Jul 3rd, 2008
i'm using cme 4.1 and i've connected 7914 to a 7961 phone. i have defined correct loads and also under the phone i have added it as a addon.
the problem is a continuos red light on 7914 and no display is coming on the module. i can ring the extension given to the module from other phones
Paolo Bevilacqua Thu, 07/03/2008 - 12:15
Hi, you need to configure the module as type under ephone, copy the firmware file S001xxxx.bin in flash, configure load 7914 as baove file without the .bin extension, and configure tftp-server for the above file.
Without all these steps, the module will not work.
Please rate post if it helps!
mohamedrishin Fri, 07/04/2008 - 09:44
yes all tat was done by me. i can ring the extension assigned to it.but no display is coming.thats the problem
also i did with an extension of .sbn not .bin right???
and the file was s105000200.sbn
Paolo Bevilacqua Sat, 07/05/2008 - 11:54
Yes, .sbn If you do "debug tftp events" with "term mon" you should see the file request coming from the phone and if the file is found.
