EIGRP serial interface shutdown makes 2600 router reload
Richard Burts Thu, 07/03/2008 - 06:59
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
sampath
Since you have not provided any configuration detail it is difficult for us to say whether there is a configuration issue. But I find it hard to think what configuration issue might cause a router reload when a serial interface is shut down.
Since you have not provided any detail about what version and what feature set you are running it is difficult to know what specific bugs might be in your software. But a shutdown of an interface resulting in reload of the router certainly sounds like a bug to me.
I would suggest that a problem like this is a good reason to look at doing a code upgrade for this router.
Rick
