Some commands allowed, TACACS+ configured wrong?
Jul 3rd, 2008
I have a test switch and TACACS+ server to try setting up TACACS+ before putting it in to production. We have 3 persons on our network team and want to make it easier to manage device access if one of us leaves. Also to have a limited account for the person that would be filling the open position for a trial period. My issue is mainly with the config file for the server I think. Also I am not 100% sure on a few AAA commands which I have read about and applied to the switch.
The "test" user can only do show ip or so I thought. It denies all other "show" commands but for some reason "show run" still will work. If any one could give me some tips on my configuration that would be greatly appreciated.
Thank you,
Kyle
##### TACACS+ Configured #####
user = test {
member = limited
login = des "encrypted password"
enable = des "encrypted password"
name = "tester"
user = admin {
config omitted
group = admin {
default service = permit
group = limited {
default service = deny
cmd = show {
permit "ip .*"
deny .*
Overall Rating: 4.3 (9 ratings)
Jagdeep Gambhir Thu, 07/03/2008 - 12:33
  • Red, 2250 points or more
On the NAS, issue debug aaa authorization and debug tacacs.
Issue show run command,
Now see if NAS is sending command " show run " to the tacacs for authorization.
~JG
~JG
lifeforce4 Mon, 07/07/2008 - 05:45
I have the debugging enabled, "tail" the two files tac_plus.log and tac_plus.acct in /var/log/. When I issue any commands it goes to the tacacs server and either allows or blocks the command. The command "show run" is still being allowed. Also there is no debugging info being displayed when I run the commands.
If its using tacacs to block all the commands besides the ones permitted and debugging is on why would it not show that?
Kyle
user = test {
member = limited
name = "tester"
user = admin {
config omitted
group = admin {
group = limited {
cmd = show {
permit "ip .*"
permit "debugging .*"
deny .*
cmd = debug {
permit .*
Jagdeep Gambhir Mon, 07/07/2008 - 06:48
Kyle,
There is a know bug is some IOS where it does not send authorization status of command "show run". Rest other commands are sent to acs but not show run.
Which IOS running on that device ? You may need to upgrade.
~JG
Do rate helpful posts
lifeforce4 Mon, 07/07/2008 - 07:21
The ISO is 12.2(25r) c3560-ipservices-mx.122-25.SEB4.bin is there a location on cisco's site for viewing known bugs? Viewing the running config might not be a problem I need to consult the other members of our networking team.
Thank you,
Kyle
Jagdeep Gambhir Mon, 07/07/2008 - 09:28
You can search it using bug tool. As you said i also think that viewing it, should not be a issue as they will not able to issue any other command.
~JG
cisco24x7 Tue, 07/08/2008 - 03:33
  • Silver, 250 points or more
I think there is something wrong with your tac_plus configuration.
I am using version c2960-lanbasek9-mz.122-25.SEE4.bin and
I have NO such issue. See below.
Here is my tac_plus configuration:
[[email protected] root]# more /etc/tacacs/tac_plus.cfg
accounting file = /var/log/tac_plus.log
key = zFgGkIooIsZ.Q
user = cciesec {
member = admin
name = "rancid user"
login = des xxxxxxx
user = $cciesec$ {
member = admin
login = des yyyyyyy
user = test {
member = limited
login = des xxxxxxx
name = "tester"
user = $test$ {
member = limited
login = des xxxxxx
name = "tester"
group = limited {
cmd = show {
permit "ip .*"
deny .*
cmd = debug {
permit .*
cmd = exit { permit .* }
cmd = enable { permit .* }
group = admin {
[[email protected] root]# telnet 192.168.0.5
Trying 192.168.0.5...
Connected to 192.168.0.5 (192.168.0.5).
Escape character is '^]'.
C
User Access Verification
Username: test
Password:
C2960>en
Password:
C2960#sh run
Command authorization failed.
C2960#sh ver
C2960#
When I log in with an "admin" account, I can do just about
everything:
C
Username: cciesec
Password:
C2960>en
Password:
C2960#conf t
Enter configuration commands, one per line. End with CNTL/Z.
C2960(config)#end
C2960#exit
Connection closed by foreign host.
As you can see, even when the user has level 15 privilege, I can still restrict
what he/she can do, as desmonstrated with account "test". That's the beauty
with tacacs authorization.
Jagdeep Gambhir Tue, 07/08/2008 - 04:57
Life force is using IOS ver c3560-ipservices-mx.122-25.SEB4
Where in you are using
Both codes are different.
cisco24x7 Tue, 07/08/2008 - 05:31
But this IOS version is the same with the
exception that I have enterprise edition where
as life force has standard edition, correct?
I can see other features may be different but
I would think that tacacs would be the same
right?
Jagdeep Gambhir Tue, 07/08/2008 - 07:03
There is a huge difference between SE and EE codes. Extra feature can result in change in behavior of existing feature set.
Other then codes we also have different hardware feature here.
The biggest difference is the 3560 does L3 while the 2960 is a L2 device only..
2960 only supports static ACL policies for authorization.
You need to have the ACL defined statically on the switch for it to apply to a user session based on successful authentication.
On 3560/3750, we support downloadable ACLs for authorization. AAA can tell the switch what ACL to apply which gets craeted dynamically on the switch. So there is less provisioing, and more automation and
intelligence.
Private VLAN is another security feature available on 3560 (not on 2960)
3560 supports more NAC features than 2960.
lifeforce4 Tue, 07/08/2008 - 07:21
Wow I did not even catch that he was talking about a 2960 instead of 3560. This is one thing that makes me worry about implementing tacacs on the whole network. with 270+ NAS connected im sure a few will have some bugs with the ISO installed on them and AAA.
Kyle
cisco24x7 Tue, 07/08/2008 - 08:33
I can say that I do not have issues with IOS
version 12.2(15)T17 and 12.3(12) on Cisco 2621
and 3640 routers, in addition what I described
in 2960.
with "test" user
C2621>en
Password:
C2621#conf t
% Invalid input detected at '^' marker.
C2621#
with "admin" user
C2621>en
Password:
C2621#conf t
C2621(config)#exit
C2621#
IOS image tested:
c2600-ik9o3s3-mz.122-15.T17.bin
c2600-ik9o3s3-mz.123-19.bin
lifeforce4 Tue, 07/08/2008 - 08:57
Thank you for the testing, I dont doubt it works on those IOS versions you have. but you have seen my configuration and it should work... yet it does not. I will try it out on a different switch with a different IOS just to make sure its not the config setup. but the IOS it self.
Kyle
Jagdeep Gambhir Wed, 07/09/2008 - 05:50
Kyle,
Please do share the outcome of your testing.
~JG
lifeforce4 Wed, 07/09/2008 - 08:12
Yes it has to be the IOS version because I just put the same AAA commands on another switch and here is the outcome.
### Switch output ###
Username: test
Password:
TestSwitch01>en
Password:
TestSwitch01#show run
Username: admin
Password:
TestSwitch01>en
Password:
TestSwitch01#show ver
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(20)EA1a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Mon 19-Apr-04 20:58 by yenanh
Image text-base: 0x80010000, data-base: 0x805A8000
c2950-i6q4l2-mz.121-20.EA1a.bin
### End ###
Its fine because we will be updating all our devices with the latest IOS very soon so I would hope maybe we wont run in to a bug like this. I'll make sure if we do that it gets reported to cisco for fixing.
Kyle
lifeforce4 Tue, 07/08/2008 - 05:51
It has to be with the IOS version because here is the config for tacacs and my testing results for loging on the swith with both accounts.
Kyle
### start tac_plus.conf ###
key = testkey
accounting file = /var/log/tac_plus.acct
default authentication = file /etc/passwd
# Users Accounts |
user = test {
member = limited
login = cleartext "logtest"
enable = cleartext "entest"
name = "tester"
user = $test$ {
member = limited
name = "tester"
user = admin {
member = admin
login = cleartext "logadmin"
enable = cleartext "enadmin"
name = "admin"
user = $admin$ {
member = admin
name = "admin"
# Group Accounts |
group = admin {
group = limited {
cmd = show {
permit "ip .*"
deny "run*"
deny .*
cmd = debug {
permit .*
cmd = exit {
permit .*
cmd = enable {
permit .*
### end tac_plus.conf ###
### start test account login ###
Username: test
Password:
testSW>en
Password:
testSW#show vlan bri
testSW#show run
Building configuration...
Current configuration : 9108 bytes
! Last configuration change at 09:49:51 EST Mon Jul 7 2008 by admin
! NVRAM config last updated at 09:55:19 EST Thu Jun 12 2008 by admin
version 12.2
output omitted
### end test account login ###
### start admin account login ###
Username: admin
Password:
testSW>en
Password:
testSW#conf t
testSW(config)#end
testSW#
### end admin account login ###
