callmanager 6.1 with NM-HD-2VE=
Jul 3rd, 2008
after an upgrade from ccm 4.1 to 6.1 i noticed that my conference resources were not registered here is the running configuration question do i need to upgrade the ios ?
also where can i find the link to configuring sccp the old way and the new way?
sccp local FastEthernet0/0
sccp ccm 10.10.11.65 identifier 2 version 4.0
sccp ccm 10.10.11.64 identifier 1 version 4.0
sccp ip precedence 3
sccp
sccp ccm group 2
associate ccm 2 priority 1
associate ccm 1 priority 2
associate profile 2 register sat-vgw1-card2
sccp ccm group 1
associate profile 1 register sat-vgw1-card1
Jaime Valencia Thu, 07/03/2008 - 06:33
  • Cisco Employee,
  • Hall of Fame,
    2011
take out the version 4.0 from:
do a no sccp and then sccp
javalenc
if this helps, please rate
ggittins Thu, 07/03/2008 - 07:08
this is what i get
SCCP Admin State: UP
Gateway IP Address: 10.10.16.32, Port Number: 2000
IP Precedence: 3
User Masked Codec list: None
Call Manager: 10.10.11.64, Port Number: 2000
Priority: N/A, Version: 3.1, Identifier: 2
Call Manager: 10.10.11.65, Port Number: 2000
Priority: N/A, Version: 3.1, Identifier: 1
SCCP application services(dspfarm profiles) are not enabled
or haven't associated to SCCP CCM group
sccp ccm 10.10.11.64 identifier 2
sccp ccm 10.10.11.65 identifier 1
sccp
sccp ccm group 2
sccp ccm group 1
paolo bevilacqua Thu, 07/03/2008 - 07:24
  • Hall of Fame,
    Founding Member
Can you check "show diag" to see how much DSP resources are actually installed there ?
Jaime Valencia Thu, 07/03/2008 - 11:10
  • Cisco Employee,
  • Hall of Fame,
    2011
what IOS are you running?, maybe it is old and you would indeed need an upgrade
at least most of the times i have tried that WA has worked just fine when taking the version
javalenc
ggittins Thu, 07/03/2008 - 11:13
is there a compatability list for module with callmanager 6.1
paolo bevilacqua Thu, 07/03/2008 - 12:19
  • Hall of Fame,
    Founding Member
Ignore, posted in error.
ggittins Thu, 07/03/2008 - 13:39
question for users using version 6.1 or 5.1 what version do they select on the sccp
mshamkumar Wed, 11/10/2010 - 08:36
Hi  javalenc you are the best voice eng and i am your big fan,why dont you add me as you student so that i can learn lots of tech and solution and i can gain lots of knowledge from you...coz every post of yours and solution posted  worked for me all the time...thank you so much....If you dont mind can i get your mail id please.....
