07-03-2008 06:31 AM - edited 03-03-2019 10:35 PM
Are the compression modules like AIM-COMPR4 and AIM-COMPR-V2 used only for WAN interfaces?
Can we use them for Ethernet interfaces?
Taha
Solved! Go to Solution.
07-03-2008 07:00 AM
No.
Compression in LAN environments doesn't make sense.
However, if you want a media-independent compression solution, use IPsec. Cisco routers can compress data using the LZS algorithm.
Please rate post if it helps!
07-03-2008 07:00 AM
No.
07-03-2008 08:47 AM
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/prod_qas0900aecd805d22f5.html
you can use this for network optimization
