[IOX 3.4 to 3.6 software upgrade procedure document]
Jul 3rd, 2008
hi, all:
does anybody have a document describing the procedure to be followed when upgrading from IOX 3.4 to 3.6? all i can find on the web is going from IOS to IOX which i don't want.
please help!
c.
swaroop.potdar Fri, 07/11/2008 - 07:01
Please see this document for more details.
http://www.cisco.com/web/Cisco_IOS_XR_Software/pdf/XR12000_Upgrade_Procedure_3_4_x_3_5_x__3_6_x_to_3_6_1.pdf
Even though everything is documented in here, please perform the procedure on your LAB routers which have identical SMU's and PIE's as your live routers, including the hardware ( i say hardware as well because if you have a firewall module in live it will have an additional pie for it, and if you have to have identical pie's in LAB then you need to have identical hw as well).
Once you perform this upgrade you can document all the steps in a MOP and forward for live upgrades.
HTH-Cheers,
Swaroop
