Cisco WAAS
Jul 3rd, 2008
How the WAN acceleration is done by the WAAS?.. I meant what is the technlogy used for doing this.
dstolt Thu, 07/03/2008 - 08:58
Without writing a book, WAAS uses TCP optimization and compression for all TCP traffic that is redirected to it. Also, on top of the basic TCP optimizations, there are also Layer 7 Application Optimization(AO). Currently in 4.0 there is a CIFS AO, but in future releases (4.1.x), there will be more AOs for things like HTTP, NFS, RTSP, etc.
Check out the following for a little more detail...
Hope that helps,
pmccubbin Thu, 07/03/2008 - 12:06
Hi Dan,
You might have mentioned the book which recently Zach wrote. ;-)
Here it is:
Deploying Cisco Wide Area Application Services (Networking Technology) (Hardcover)
by Zach Seils (Author), Joel Christner (Author).
Parthiban, I own it and recommend it to everyone who is tasked with deploying Cisco WAAS.
Hope this helps.
dstolt Tue, 07/08/2008 - 05:01
It's the best resource you can read on the subject from the formost expert on WAAS....anywhere.
