i recieved port 1645 & 1646 without configured them ???????????????........
tareqrebhi
Dears i had configured my AS5400:
aaa authentication login default local group radius
aaa authentication login h323 group radius
aaa authentication ppp h323 group radius
aaa authorization exec h323 group radius
aaa authorization network h323 group radius
aaa accounting network h323 start-stop group radius
aaa accounting connection h323 start-stop group radius
radius-server attribute 6 on-for-login-auth
radius-server host 55.55.55.15 auth-port 1812 acct-port 1813
radius-server timeout 50
radius-server deadtime 1
radius-server key xxx
radius-server vsa send accounting
radius-server vsa send authentication
but i have recieved port 1645 as follow:
*Jan 9 21:50:07.194: RADIUS(000C39C6): Send Accounting-Request to 55.55.55.21:1813 id 1646/187, len 1020
*Jan 9 21:50:07.222: RADIUS: Received from id 1646/187 55.55.55.21:1813, Accounting-response, len 20
*Jan 9 21:50:09.694: RADIUS/ENCODE: Best Local IP-Address 55.55.55.49 for Radius-Server 55.55.55.21
*Jan 9 21:50:09.694: RADIUS(000C36E8): Send Accounting-Request to 55.55.55.21:1813 id 1646/192, len 1123
*Jan 9 21:50:18.774: RADIUS(000C3A7E): Send Accounting-Request to 55.55.55.21:1813 id 1646/209, len 705
why port 1646 appeared here i don't configured 1646 at my configuration.
Does this from Raduis server ... what i mean this port (1646) is configured at Raduis server
thank you ...
7 Replies 7
michael.leblanc
Level 4
Level 4
It would have been helpful if you had identified the device with address 55.55.55.21, as this is not the address of the RADIUS server shown in your configuration snip.
It appears that your ASA is using a "UDP source port of 1646" when it sends packets to what I assume is another RADIUS server (55.55.55.21).
UDP port 1646 was used for accounting prior to the assignment of 1813. Some of our Catalyst switches use UDP source port 1646 also.
ok is this normal or it is error in the configuration of AS5400 device?
but my raduis server is configured with port 1813 not 1646.
what your suggestion for my AS5400 configuration to send AAA packet with only port 1813?
BR,
If the device with address 55.55.55.21 is a RADIUS server (still unconfirmed), and if my interpretation of the log messages is correct (i.e.: ASA using UDP source port 1646, and destination port 1813), there is no issue to be concerned with.
As you've stated, your RADIUS server is configured to "listen" on port 1813. Your ASA is sending packets to port 1813 on the RADIUS server, not port 1646.
Each device has an open port. The ASA has port 1646 open, and the RADIUS server has port 1813 open.
Packets sent from the ASA to the RADIUS server have a source port of 1646 and a destination port of 1813.
Packets sent from the RADIUS server to the ASA have a source port of 1813 and a destination port of 1646, because the ASA is listening on port 1646.
It isn't very relevant which port the ASA listens on for the AAA Accounting exchanges.
If you use a sniffer to capture an exchange you will determine very quickly whether the log entries have been interpreted correctly.
I don't believe packets are being sent to both ports on the RADIUS server, and I don't believe you have an ASA configuration error.
yes exactly 55.55.55.21 is raduis server and 55.55.55.49 it is my AS5400.
i have FW is located between them and i used these ACL lists:
access-list 100 extended permit tcp any host 55.55.55.21 eq 1812
access-list 100 extended permit tcp any host 55.55.55.21 eq 1813
access-list 100 extended permit tcp any host 55.55.55.21 eq 1645
access-list 100 extended permit tcp any host 55.55.55.21 eq 1646
is there other command should to be used?
Thank you.
If you examine your ACL Access Control Entries do you see "matches" on the first two:
... and NOT on the second two:
... if so, the AS5400 is not sending packets to "destination" ports 1645 or 1646 on the RADIUS server.
Dear this output:
TARASA-02# sh access-list | include 1646
access-list 100 line 88 extended permit tcp any host 55.55.55.21 eq 1646 (hitcnt=0) 0xb9e532a6
access-list 101 line 44 extended permit tcp host 55.55.55.21 any eq 1646 (hitcnt=0) 0x4599a6ce
TARASA-02# sh access-list | include 1813
access-list 100 line 80 extended permit udp any host 55.55.55.21 eq 1813 (hitcnt=0) 0x68f2332e
access-list 100 line 86 extended permit tcp any host 55.55.55.21 eq 1813 (hitcnt=0) 0xdfdcbee0
access-list 101 line 34 extended permit udp host 55.55.55.21 any eq 1813 (hitcnt=0) 0xc4ebdbc9
access-list 101 line 42 extended permit tcp host 55.55.55.21 any eq 1813 (hitcnt=0) 0x23741a92
TARASA-02# sh access-list | include 1812
access-list 100 line 79 extended permit udp any host 55.55.55.21 eq 1812 (hitcnt=0) 0x434c493f
access-list 100 line 85 extended permit tcp any host 55.55.55.21 eq 1812 (hitcnt=0) 0x1eaca25d
access-list 101 line 33 extended permit udp host 55.55.55.21 any eq 1812 (hitcnt=0) 0x1b49f068
access-list 101 line 41 extended permit tcp host 55.55.55.21 any eq 1812 (hitcnt=0) 0x20268376
TARASA-02# sh access-list | include 1645
access-list 100 line 87 extended permit tcp any host 55.55.55.21 eq 1645 (hitcnt=0) 0xa53ef213
access-list 101 line 43 extended permit tcp host 55.55.55.21 any eq 1645 (hitcnt=0) 0xb52e86b8
do these mean there is error in configuration or raduis packet from AS5400?
BR,
RADIUS uses UDP, and not TCP.
You have erroneously specified TCP in many of your Access Control Entries, and you have specified destination ports 1645 and 1646 on the RADIUS server which I do not believe is necessary.
Assuming you have performed some action that would have resulted in an AAA operation since the counters were last reset, I would expect the hit counts for the following two ACEs to be non-zero:
... the fact that they are zero "may" suggest that the ACEs are applied on the wrong interface, or in the wrong direction, or a more permisive ACE is being matched.
The following two ACEs can be deleted because they specify TCP, and UDP versions of these are in effect above:
The following two ACEs can be deleted because they specify TCP, and I don't beleive you need to create UDP versions of them because I don't beleive your ASA is sending packets to these ports on the RADIUS server:
You "may" need to retain the following two ACEs "if" you have other AAA Clients using local UDP ports 1812 and 1813 (I think your ASA is listening on 1645 and 1646):
The following two ACEs need to be amended (UDP, not TCP), to support return traffic to the ASA which I believe is listening on UDP ports 1645 and 1646:
The messages in your original post suggest that accounting is working (you haven't suggested otherwise), despite the fact that none of the ACEs provided show any hits. I don't know if you have a more permisive ACE that is being matched or if you reset the counters prior to pasting the ACEs in your most recent post.
I still think you should use a sniffer to verify that the ASA is using ports 1645 and 1646 locally to communicate with ports 1812 and 1813 on the RADIUS server. Then review your ACLs to ensure that your ACEs are constructed accordingly, and that your ACLs are applied in the correct direction, on the correct interfaces. The hit counters are an easy means of verification.
