APs AIR-AP1131AG-A-K9 channels distribution question.
Jul 3rd, 2008
I need to intall 04 Aps in an area where all of them have contact. I now know that the best practice is to use the three channels combination, but what would be the best way to do it? How could I use the 4 APs considering that two of them will be in an meeting room where I need to guarantee around 60 connections?
Overall Rating: 5 (1 ratings)
jeromehenry_2 Thu, 07/03/2008 - 08:06
I do not know the scale of your map, but can you try to play with the power level (reduce AP power level to a minimum) and the antenna type (use a low gain patch antenna to isolate the beams from each other)?
luiz.alexandre.... Thu, 07/03/2008 - 09:32
Thanks for your feedback about the power levels, do you know where can I find the material about it? And about the antenna we haven't purchased no external antennas, so I believe that will have to deal with power level.
Rds,
Alexandre
Scott Fella Thu, 07/03/2008 - 13:57
You can do it this way:
AP-A Channel 1
AP-B Channel 6
AP-C Channel 11
AP-D Channel 1
AP-A & AP-D is where you would reduce the TX power.
http://www.cisco.com/en/US/docs/wireless/access_point/12.3_8_JA/command/reference/cr38main.html#wp2459939
You may want to also want to adjust the client power:
http://www.cisco.com/en/US/docs/wireless/access_point/12.3_8_JA/command/reference/cr38main.html#wp2459814
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
