ASA 5510 - Re-Boot issue
Jul 3rd, 2008
Hi folks,
I'm fairly new to this, but in doing configuring/testing of 5510s, I have an issue with just one unit. I'm bringing the SCL up to level 5 from either 0 or 2, then doing a config. for our customer, then running a test on all the connectivity. Once that is done, I then reload to factory defaults at which point this one unit fails to re-boot properly and I get the mssg.: Autoboot failed, rebooting. The unit then gets into a loop of cycling through this until I gave up and shut it down. Could it be a bad SSM Module, or is the mainboard messed up? Any thoughts might help me out come Monday when I go back to work... (General Dynamics C4 Systems). Thanks for any input.
earl1casey Wed, 07/09/2008 - 12:12
Thank You for the response. It may be that it was intermittent, as several attempts w/in an hour resulted in the same issue,but it was resolved at least through one test cycle on the following business day. I shall pass the info you posted here on to my colleagues. Once again, Thanks!
