Cisco-Avaya integration licensing
Jul 3rd, 2008
Hello all,
I am planing to integrate an Avaya G3 V12 with a CCM 5.1. I am thinking of using either:
1) A SIP trunk btw Avaya G3 and CCM 5.1
2) a Cisco 2851 (CME) Gatway with PRI
My question is how the licencing is going to work. Do I need to buy any licences for this integration? If so, is it going to be per user or it comes in bundle? If you have any previous Avaya-Cisco integration experience and know how much the licencing will cost, please let me know.
Overall Rating: 3 (2 ratings)
Paolo Bevilacqua Thu, 07/03/2008 - 12:17
Hi, from the cisco side, no licensing of any type is needed for what you exposed above.
Please rate post if it helps!
mightyking Thu, 07/03/2008 - 12:20
Thanks Paolo,
If any one has any idea about Avaya for the licensing and how much it gonna cost, please let me know.
louis.engelbrecht Fri, 07/04/2008 - 06:48
I have done this recently with a h323 gateway integration between avaya and cisco call manager.
on the avaya side you will need to buy a 3rd party vendor support license to enable the needed features. i think this was particularly for h323, so not sure for sip.
