agent desktop window behavior
Jul 3rd, 2008
We are using agent desktop 6.4.2 with IPCC express 5.0. We have a handful of users on Windows vista and I have set the window behavior in the desktop administrator to be normal (maximize when a call comes in, minimize when not on a call). These users have reported that their agent desktop window continues to maximize even when they are not on a call (mostly when they are writing an email) I have only seen this behavior with the windows Vista machines.
david.macias Fri, 07/04/2008 - 04:43
  • Blue, 1500 points or more
I don't think Vista is supported yet, however one thing I would suggest is a uninstall and reinstall and see if that clears the problem.
david
Riccardo Bua Fri, 07/04/2008 - 06:42
  • Cisco Employee,
unfortunately Vista is not yet supported, please check the release notes.
Riccardo
sementellic Sat, 07/05/2008 - 07:08
According to the compatibility matrix IPCC 5.0.2 supports vista. I also had a tac engineer verify and confirm this....
