Need help on callmanager 4.1
Jul 3rd, 2008
Need to call the customer and check whether they have changed the (fans/powersup
Dear Friends I want to know how to find how many license is used in the call manager 4.1. is there any way to find out how many licnese is used? where to see how to see?
Gem
Jaime Valencia Thu, 07/03/2008 - 12:34
  • Cisco Employee,
  • Hall of Fame,
    2011
the concept of license and/or DLUs is for linux appliances 5.x and 6.x, not for windows versions
javalenc
if this helps, please rate
esa786_2 Thu, 07/03/2008 - 15:45
Hi Javalenc. So For ccm 4.1, we can use any number of devices.There must be restriction or how many device that ccm can support. Because you must be knowing, deach device have some weightage ( some unit). pls explain
regards
gem
