Transfer/conference only works one way
Jul 3rd, 2008
When transferring calls from site to site over a wan it only works in one direction. I am able to call a station at the other site but as soon as I hit transfer the station at the far end rings busy. If the station at the far end transfers to me, it works. The far end is a SRST. Everythings looks to be programmed correctly. The two sites have their on device pools.
maharris Thu, 07/03/2008 - 13:32
This sounds like a codec problem - are the calls you are trying to transfer over there originating from a gateway, or just another ip phone in your area?
Mary Beth
rmckerrall1 Mon, 07/07/2008 - 11:53
Hi there,
They are originating from the gateway. Only calls from the outside. Thanks
maharris Tue, 07/08/2008 - 08:31
So probably your gateway is trying to use a codec that your regions config does not want to allow. The gateway might need to have a media resource group that has a transcoder, or if it is H323, you would want to have a codec class built that would allow the codec that you need to use to get to the other site.
Mary Beth
