VPN Tunnel
Jul 3rd, 2008
We have a VPN 3005 Concentrator. One of my users is using Netvanta 3448 from Adtran. When he connects through VPN client, he can't access his internal network (printers, file sharing, etc.) What can he do so he can access his internal network while connecting through VPN? Thanks.
Overall Rating: 5 (1 ratings)
Diane,
One of two things is possibly happening:-
1) The VPN profile is configured to encrypt all traffic.
2) You have configured split-tunneling, but the users LAN is the same subnet as the encrypted LAN.
Check you configuration on the 3005 - and ask the remote user what LAN IP Subnet they are using.
HTH.
dianewalker Fri, 07/04/2008 - 05:36
We have configured Split Tunneling on the VPN Concentrator. The remote user is using the private IP address of 172.31.
Thanks.
dianewalker Fri, 07/04/2008 - 16:47
When remote users connect through VPN successfully, the IP address is assigned by the VPN Concentrator. The IP address is 169.230.XXX.XXX.
Thanks.
dianewalker Sat, 07/05/2008 - 05:33
The internal IP addresses from DHCP from the Concentrator are from 169.230.251.100 to 169.230.251.200.
Thanks.
dianewalker Tue, 07/08/2008 - 13:45
Jill,
Thanks for the information. It fixed the problem.
Diane
