wism occur strange message on management log
Jul 3rd, 2008
Hi there,
I got the strange messages on my wism(v4.1.158.0)
Jul 03 14:41:24.148 apf_foreignap.c:1246 APF-1-REGISTER_IPADD_ON_MSCB_FAILED: Could not Register IP Add on MSCB. MSCB still in init state. Address:00:1a:70:a6:b9:fe
Jul 03 14:41:22.821 apf_foreignap.c:1246 APF-1-REGISTER_IPADD_ON_MSCB_FAILED: Could not Register IP Add on MSCB. MSCB still in init state. Address:00:18:39:0b:93:04
Jul 03 14:41:22.820 apf_foreignap.c:1246 APF-1-REGISTER_IPADD_ON_MSCB_FAILED: Could not Register IP Add on MSCB. MSCB still in init state. Address:00:18:39:0b:93:04
Jul 03 14:41:21.618 apf_foreignap.c:1246 APF-1-REGISTER_IPADD_ON_MSCB_FAILED: Could not Register IP Add on MSCB. MSCB still in init state. Address:00:16:b6:92:d1:1e
Jul 03 14:41:21.601 apf_foreignap.c:1246 APF-1-REGISTER_IPADD_ON_MSCB_FAILED: Could not Register IP Add on MSCB. MSCB still in init state. Address:00:16:b6:92:d1:1e
Previous message occurred 2 times.
Jul 03 14:41:21.600 apf_foreignap.c:1246 APF-1-REGISTER_IPADD_ON_MSCB_FAILED: Could not Register IP Add on MSCB. MSCB still in init state. Address:00:16:b6:92:d1:1e
Jul 03 14:41:19.698 apf_foreignap.c:1246 APF-1-REGISTER_IPADD_ON_MSCB_FAILED: Could not Register IP Add on MSCB. MSCB still in init state. Address:00:16:b6:92:d1:1e
Jul 03 14:41:19.688 apf_foreignap.c:1246 APF-1-REGISTER_IPADD_ON_MSCB_FAILED: Could not Register IP Add on MSCB. MSCB still in init state. Address:00:16:b6:92:d1:1e
Jul 03 14:41:19.687 apf_foreignap.c:1246 APF-1-REGISTER_IPADD_ON_MSCB_FAILED: Could not Register IP Add on MSCB. MSCB still in init state. Address:00:16:b6:92:d1:1e
Jul 03 14:41:19.300 apf_foreignap.c:1246 APF-1-REGISTER_IPADD_ON_MSCB_FAILED: Could not Register IP Add on MSCB. MSCB still in init state. Address:00:1a:70:a6:b8:ff
And the clients have the MAC on the log couldn't forward any packet to the network.
I couldn't find any idea on the CCO.
Do you have any idea about this message?
regards,
Jongkwan
Scott Fella Thu, 07/03/2008 - 18:19
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Found this.... Might help hopefully, but its just a brief description, but at the end, of course.... call TAC
Error Message %APF-1-REGISTER_IPADD_ON_MSCB_FAILED: Could not Register IP Add on
MSCB. [chars]. Address:[hex]:[hex]:[hex]:[hex]:[hex]:[hex]
Explanation Could not Register IP Add on MSCB.
Recommended Action Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/launch.do, or contact your Cisco technical support representative and provide the representative with the information you have gathered.
Search for REGISTER_IPADD_ON_MSCB_FAILED
http://www.cisco.com/en/US/docs/wireless/controller/message/guide/msgs2.html
Scott Fella Sat, 07/05/2008 - 09:28
  • Hall of Fame,
    2017 Wireless
The code you are running isn't on CCO anymore, at least I can't find it on the WiSM. If you don't have any MESH, then you should upgrade to 4.1.185. If you have 1252's then 4.2.130.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
