Netmeeting (Urgent)
Jul 3rd, 2008
Hi, I need to setup Netmeeting to coonect DMZ Server from Outside Network. For this I have opened the Netmeeting ports for outside access but still I am not able to make connectivity by netmeeting from Outside Network. I reviewed inspection logs and it doesn't show any deny packet. Please advice...
ray_stone Thu, 07/03/2008 - 23:20
Yes, NAT is configured and assigned static public IP to all DMZ Servers.
dhananjoy chowdhury Thu, 07/03/2008 - 23:30
Could you share the NAT and access-lists statements (removing the sensitive info).
Try to access and check whether NAt is happening
"show xlate"
try command "clear xlate" and try to access again.
ray_stone Thu, 07/03/2008 - 23:41
Well, I have already used these commands but still problem persists. Could it be a issue of protocol which can be fixed by fixup command? Please advice..
dhananjoy chowdhury Fri, 07/04/2008 - 00:52
Yes you can try the fixup -
policy-map global_policy
class inspection_default
inspect h323 h225
inspect h323 ras
