X.25 switching.
Overall Rating: 4 (1 ratings)
paolo bevilacqua Fri, 07/04/2008 - 01:04
  • Hall of Fame,
    Founding Member
Which cable are you using? Send output of "show controllers serial 0/3/0".
paolo bevilacqua Fri, 07/04/2008 - 02:45
  • Hall of Fame,
    Founding Member
Hi, beside that it is showing "not attached", you need a DCE cable, CAB-SS-232FC.
You cannot use any other type of cable and you cannot make any configuration to make work the one that you have.
Please rate post if it helps!
a.alekseev Fri, 07/04/2008 - 05:58
  • Gold, 750 points or more
Can Solaris provide clock?
