LDAP SDK Phone Service
Jul 3rd, 2008
Per
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/4x/42drctry.html#wp1047576
there are 4 options and I want to setup the first one "Directory access" via "Cisco Unified IP Phone Services SDK"
I installed SDK on my Unity server and am using the LDAP sample asp which I hope is the right one to use. I'm new to SDK and not much of a web guy. I have a centralized CM topology and want to:
Query Active Directory by pointing the script to a Global Catalog server with specifying port 3268 in the script configuration
Need some direction on how to customize the asp sample scripts as it is suppose
Overall Rating: 1 (2 ratings)
