reset port settings
Answered Question
Jul 3rd, 2008
lets say i have some configurations on a port and i want to remove all these configurations, i dont wish to use the No command before each line .
how can i remove for example 6 configurations ina single command line ? that is to reset the port to a non configured port
Correct Answer by n.nandrekar about 8 years 7 months ago
hi!
You can use the "default interface giX/X " command in the config mode. It will reset the interface to its defaults.
Niranjan.
(pls rate helpful posts)
Overall Rating: 5 (1 ratings)
Correct Answer
n.nandrekar Thu, 07/03/2008 - 23:53
hi!
Niranjan.
