C3660 as an IPIP Gateway
Jul 4th, 2008
Hi all,
does anyone know if an Old C3660 can act as an IPIP gateway. See below for the descriotion on the setup
CCM and Avaya IP PBX- > C3660 H323 GW -> remote H323 GW -> CCM or CCME
Paolo Bevilacqua Fri, 07/04/2008 - 04:20
Should work. Beside that, what prevents you from setting IP connectivity between the CCMs?
That would let you a much simpler solution.
