vpn-idle-timeout on Pix 6.3
Jul 4th, 2008
how can I set
vpn-idle-timeout none
on a PIX 6.3 software? Is it something that exists only for 7.x?
If yes, is there any other way to stop vpn from dropping after a certain period of inactivity?
Overall Rating: 5 (1 ratings)
owillins Thu, 07/10/2008 - 09:06
In version 6.3, the idle timeout was appliable only to VPN client connections.. In Version 7.0, the 30-minute idle timeout applies to both client and LAN-to-LAN tunnels. To remove the idle timeout on LAN-to-LAN tunnels and restore the 6.3 behavior, you must create a new group-policy and specify none for the vpn-idle-timeout value.
http://www.cisco.com/en/US/docs/security/asa/asa70/pix_upgrade/upgrade/guide/pixupgrd.html
