PBR: set ip default next-hop
Answered Question
Jul 4th, 2008
Just a quick question about policy-based routing. For example, packets
that came from 10.0.0.0/8 going to 20.0.0.0/8 should be routed to
next-hop 1.0.0.1. I used the command set ip default next-hop 1.0.0.1. If
the routing table has an entry for 20.0.0.0/8 (for example an OSPF/EIGRP
entry) network then the policy routing shouldn't work right? The route
entry for 20.0.0.0/8 should be removed from the routing table in order
for PBR to work. That's my understanding between set ip default next-hop
and set ip next-hop. Where set ip next-hop command routes the packet to
the next hop router ignoring the route entry in the routing table. Am I
understanding it correctly?
For the set ip default next-hop, what if 20.0.0.0/8 was gone in the
routing table but there was a default-route, the policy-routing should
still work right? Default-route entry is being ignored in this case.
Please correct me if I'm wrong. Thanks.
John
Correct Answer by foxbatreco about 9 years 3 weeks ago
Yes..the policy route will be used if the route in question is no longer in route table , even if the default path is available.
Overall Rating: 5 (2 ratings)
foxbatreco Fri, 07/04/2008 - 08:21
  • Bronze, 100 points or more
With set ip default next-hop ,if the 20.0.0.0/8 entry is found in route table, it will not use policy routed configuration but will use the path in the routing table.
If u need to override the route table entry, u will have to use set ip next-hop.
Pls rate/mark if this helps!!!
John Patrick Lopez Fri, 07/04/2008 - 08:57
Yes that's what I understand. What about the default-route? If the 20.0.0.0/8 was gone in the routing table but the routing-table has a default-route, will it still be policy routed or will it follow the default-route?
Correct Answer
foxbatreco Sat, 07/05/2008 - 11:36
Edison Ortiz Fri, 07/04/2008 - 17:17
  • Hall of Fame,
    Founding Member
You are correct
__
Edison.
