Compare OSPF metric-type 1 and 2
Jul 4th, 2008
I try to redistribute static route from Router 16A and 16B
with metric-type 2 and metric-type 1 respectively. I think metric 2 will be chosen by Router 2600
as lower metric (20) compared with metric 1 (30).
However, after simulation, router 2600 has route {E1 [110/30] via}
installed. After Router 2600 E0/1 down. 2600 has route {E2 [110/20] via}
Anyone know why Router 2600 chose E1 route rather than E2 route ?
Overall Rating: 3 (2 ratings)
ccnpninja Mon, 10/20/2008 - 10:23
Is it an exception in routing?
Logically, router 2600 will choose to insert the E2 route in its routing table because it has a lower metric (both routes having the same prefix and the same Admin Distance).
Am I missing something?
Giuseppe Larosa Mon, 10/20/2008 - 11:44
Hello Wassim,
O E1 are preferred over O E2 because they are seen as more detailed for the fact that the metric is the sum of seed metric and internal metric to ASBR: see your own thread on O E1 metrics as seen by neighbor.
Hope to help
