ASA 5520 and a single VPN question
Jul 4th, 2008
Simple question, so sorry for the description.
I could.nt find where this would appear in the CLI, but on our ASA 5520's ASDM console if I go to Monitoring > VPN Statistsics > Sessions > Filter by Site-to-Site > Select a VPN and choose details > within details there is a ACL tab.
Mine says "ACLs are not being applied to this session"
Think is I have "no sysopt connection permit-vpn" on my config so I have had to create many ACE's within the default ACL's. So should I be worried?
Thing is I know ACL's/ACE's are in use because if I disable them then the traffic stops flowing over the VPN.
whiteford Fri, 07/04/2008 - 11:11
Where do I find that looks great?
What are filters in a nut shell then? Is it another way of firewalling VPN traffic? If so I do prefer the ACE method I have done.
a.alekseev Fri, 07/04/2008 - 23:50
tools -> preferences
these filters are ACLs for traffic going within IPsec tunnel.
whiteford Sat, 07/05/2008 - 00:11
I have done tools -> preferences thanks.
Are filters better than the way I'm doing it by controling traffic by ACE's in the Inside and Outside ACL/Interfaces of the ASA?
