paolo bevilacqua Fri, 07/04/2008 - 08:54
  • Hall of Fame,
    Founding Member
First one was configured in nvram at startup.
Second one has been configure manually with in a config session.
Really what the router says :)
paolo bevilacqua Fri, 07/04/2008 - 15:13
  • Hall of Fame,
    Founding Member
Are you familiar with the concept of "startup configuration" and "config term" in IOS ?
Edison Ortiz Fri, 07/04/2008 - 17:15
  • Hall of Fame,
    Founding Member
As Paolo stated, when you see an interface listed with Manual it means the IP address was configured on that interface after the router was rebooted.
For instance:
Router(config)#int s0/0
Router(config-if)#ip add 192.168.1.1 255.255.255.0
Router(config-if)#no shut
Router(config-if)#end
Router#sh ip int bri
*May 10 11:42:49.843: %SYS-5-CONFIG_I: Configured from console by console
Serial0/0 192.168.1.1 YES manual up up
Now, if I reboot the router, the interface chances to NVRAM.
Serial0/0 192.168.1.1 YES NVRAM up up
HTH,
__
Edison.
Please rate helpful posts
