VPN Client Cert Chain Issues
Jul 4th, 2008
I am attempting to setup a VPN connection on a new computer. This connection currently works fine on another machine. I have installed the Root Cert chain and my personal cert as before and it fails to connect. I have included my log file below. The cert shows as valid so I am unsure what I have done wrong. I have done this for other machines and it has worked fine. Any help would be appreciated!
Thank you
Karl
Cisco Systems VPN Client Version 4.8.01.0300
Copyright (C) 1998-2005 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 5.1.2600 Service Pack 3
109 10:24:39.791 07/04/08 Sev=Info/6 CERT/0x63600025
Attempting to find a Certificate using Serial Hash.
110 10:24:39.791 07/04/08 Sev=Info/6 CERT/0x63600026
Found a Certificate using Serial Hash.
111 10:24:39.791 07/04/08 Sev=Info/6 CERT/0x63600025
112 10:24:39.791 07/04/08 Sev=Info/6 CERT/0x63600026
113 10:24:39.791 07/04/08 Sev=Info/6 CERT/0x63600025
114 10:24:39.791 07/04/08 Sev=Info/6 CERT/0x63600026
115 10:24:39.870 07/04/08 Sev=Info/4 CERT/0x63600015
Cert (cn=XXXXXXXXXXXXXX,ou=CSADMIN,dc=secure,dc=XXXXXXXXXXXX,dc=com) verification succeeded.
116 10:24:40.901 07/04/08 Sev=Info/6 CERT/0x63600025
117 10:24:40.901 07/04/08 Sev=Info/6 CERT/0x63600026
118 10:24:41.135 07/04/08 Sev=Info/4 CERT/0x6360001B
No smart card readers with cards inserted found.
119 10:24:41.432 07/04/08 Sev=Warning/2 CERT/0xE360003E
Cert chain missing or intermediate CA signature failed - Cert verification failed.
120 10:24:41.432 07/04/08 Sev=Warning/2 IKE/0xE3000097
Unable to validate peer certificate, Common Name co-sec-vpn01.ou=secure.ou=XXXXXXXXXXXX.o=com., Issuer cn=CPI,dc=secure,dc=XXXXXXXXXXX,dc=com, (CertCfg:241).
121 10:24:41.432 07/04/08 Sev=Warning/2 IKE/0xE300009B
Failed to process MM Msg 6 (NavigatorMM:570)
122 10:24:41.432 07/04/08 Sev=Warning/2 IKE/0xE30000A7
Unexpected SW error occurred while processing Identity Protection (Main Mode) negotiator:(Navigator:2237)
mchin345 Thu, 07/10/2008 - 06:32
  • Silver, 250 points or more
VPN connection was not established because of an unrecognized reason. Please check the logs for details. Better solution is Install an Identity Cert that is not chained.
