07-04-2008 10:29 AM - edited 03-18-2019 09:14 PM
I am working on CME+CUE now a days. I did configure CUE for testing purpose and now i want to remove all configuration and want that Initial configuration Wizard again through GUI. I tried to find solution but one document said probably we can have that GUI wizard only first and never after that.
Please waiting for your reply
Rameez
Solved! Go to Solution.
07-05-2008 07:05 PM
You should be able to do a 'factory restore' if you've got a somewhat recent CUE version (at least 2.1, I believe). Just access it via the CLI, enter 'offline', and then you can do the 'restore factory default'.
07-05-2008 07:05 PM
