remote access vpn idle timers question
Jul 4th, 2008
Hello, I was wondering if someone could please tell me if there is any sort of traffic or timers that may reset the vpn idle timer. I have tried to set it to disconnect after 5 minutes, but when I leave the session idle (few hours to overnight), the connection remains intact. I would like to set up it up so that it idles out after thirty minutes of inactivity, but I am not sure what I may need to modify in order to accomplish this. Thanks.
Overall Rating: 1 (1 ratings)
a.alekseev Fri, 07/04/2008 - 23:33
  • Gold, 750 points or more
I think all ok with your timers.
But there is no inactivity.
Could you check encrypted/decrypted statistics on you vpn client?
jedrekmaly Tue, 07/08/2008 - 08:53
I am assuming there is no inactivity since there is more packets decrypted then encrypted, which is causing the idle timers to be reset?
jedrekmaly Fri, 07/11/2008 - 05:48
I am new to the ASAs and I have no idea where to even proceed or go from here.
