Switch thinks it's root while it's actually not
Answered Question
Jul 4th, 2008
Our server guys got two new c7000 blade enclosures, and I set up the blade switches (3120X) that came w/ them.
I set them up as a single VBS.
After connecting the switch stack to our DC aggr 6513, it somehow says it's the root of EVERY vlan!
Checked the priority of the new switch, it's got the higher number than the actual root.
I hardcode the priority to 64400 (or something close to it), same thing.
Has anyone seen anything like this?
Correct Answer by Jon Marshall about 9 years 2 weeks ago
You are only allowing vlans 3,6 & 13 across the trunk link from the 6500 switches. So if you look at the spanning-tree for these vlans on the 3120's they should be reporting the 6500's as STP root.
But for all the other vlans by not allowing them across the trunk you stop STP running across the trunk for those vlans so both will think they are root.
Solution depends on what you are trying to achieve
1) By only allowing 3,6,13 on the link it sounds like these are the only vlans present on the 3120 switches. If so you could make the 3120 switches VTP transparent and only have those vlans created on the switches.
2) Rather than using allowed you can prune the trunk link. If you prune then STP will still run across the link for the pruned vlans so the 3120's should see the 6500 switches as root for all vlans. Be careful not to use a list of vlans with the prune command though as this has the same effect as using the "allowed" keyword ie. it stops STP for vlans not in the list.
Jon
Overall Rating: 5 (1 ratings)
n.nandrekar Sat, 07/05/2008 - 03:51
  • Silver, 250 points or more
hi!!
In case of spanning tree, the switch with a "LOWER" priority becomes the root bridge. Hoping that I am understanding your problem correctly, you need to "DECREASE" the priority of the new switch to a value lesser than 6513 in order to make the new switch as the root bridge.
Niranjan
(pls rate helpful posts)
huangedmc Sat, 07/05/2008 - 05:29
We don't want the new switch to be root.
Our problem is that even though the new switch has a higher priority, it says it's the root for all the vlan's.
n.nandrekar Sat, 07/05/2008 - 08:02
Oh!! Your statement in the original post...."Checked the priority of the new switch, it's got the higher number than the actual root. "
was contradicting what you said in the latest post. Hence that was my reply.
Anyways, to troubleshoot,
1. Are both switches connected using a trunk?
2. Does the 6500 also recognize the new switch as the root? or are both declaring themselves as the root? it could tell us that one of them is not receiving/processing the other's bpdus.
3. Is it possible for you to paste "sh spanning-tree" from both the switches? and also the connected port configs?
Niranjan
huangedmc Sat, 07/05/2008 - 14:38
Switches are connected via trunk ports, and both declare themselves as root.
6513:
interface GigabitEthernet12/35
description CS-BE-34-179
switchport
switchport trunk allowed vlan 3,6,13
switchport mode trunk
no ip address
speed 1000
duplex full
channel-group 2 mode active
end
CS-SWHC-0-2#sh run int g13/40
Building configuration...
Current configuration : 244 bytes
interface GigabitEthernet13/40
switchport
no ip address
speed 1000
duplex full
end
CS-SWHC-0-2#sh run int po2
Current configuration : 183 bytes
interface Port-channel2
switchport
no ip address
end
3120X:
interface GigabitEthernet1/0/23
speed 1000
duplex full
channel-group 1 mode active
interface GigabitEthernet3/0/23
!I shut down the port as part of troubleshooting procedure
shutdown
speed 1000
duplex full
interface Port-channel1
description PO to 6513-1
We have too many VLAN's so I'm only copying one of them:
6513:
CS-SWHC-0-2#sh spanning-tree
VLAN0001
Spanning tree enabled protocol rstp
Root ID Priority 24577
Address 0009.1228.6e40
This bridge is the root
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 24577 (priority 24576 sys-id-ext 1)
Aging Time 300
Interface Role Sts Cost Prio.Nbr Type
Gi1/2 Desg FWD 4 128.2 P2p Peer(STP)
3120X:
VLAN0001
Root ID Priority 49153
Address 0021.a1b7.b600
Bridge ID Priority 49153 (priority 49152 sys-id-ext 1)
Aging Time 300
UplinkFast enabled but inactive in rapid-pvst mode
Po1 Desg FWD 3004 128.488 P2p
Correct Answer
Jon Marshall Sat, 07/05/2008 - 23:32
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jon
Giuseppe Larosa Sun, 07/06/2008 - 02:58
  • Hall of Fame,
    Founding Member
what is important is what happens for the vlans permitted on the trunk
do a sh spanning-tree vlan 3
sh spanning-tree vlan vlan 6
sh spanning-tree vlan vlan 13
the root bridge for these should be the 6513 if using rapid per vlan STP.
If so it is ok.
If using a different type of STP like MST you may need to allow also vlan 1 on the trunk, because in this case BPDUs are not sent out on every vlan. The IST (spanning tree instance 0) will carry info for all the defined instances inside its BDPUs.
hope to help
Giuseppe
