WDS and Microsoft IAS authentication
Jul 4th, 2008
Hi all,
I have a WiFi environment with a WDS AP (local RADIUS) and about 10 infrastructure AP's. The WDS does LEAP authentication/fast roaming for the 7921G phones.
Now I have to build up a new SSID/VLAN with 802.1x/PEAP/MS-CHAP V2 (on IAS) authentication.
Unfortunately, each infrastructure AP can authenticate the client only when wlccp is deactivated.
Is there a way to use the WDS/LEAP as a local raduis and send Infrustucture authentications to it, but still send user authentications to the IAS?
The 7921G can't be authenticated on the IAS (security issue).
Norbert
Overall Rating: 4 (2 ratings)
Richard Atkin Mon, 07/07/2008 - 03:33
Hi Norbert,
WDS certainly does support PEAP-MSCHAPv2, so I'd suggest it's just a case of troubleshooting the setup until you get it all working. A few references you may find useful...
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801c951f.shtml
http://supportwiki.cisco.com/ViewWiki/index.php/Special:Search?ns0=1&ns100=1&ns102=1&ns106=1&search=peap+wds&searchx=Search
alig.norbert Mon, 07/07/2008 - 07:27
Thanks for the reply. I've found the "hint".
On the WDS-AP (IAS is 192.168.1.3):
aaa group server radius GRP-DOT1x
server 192.168.1.3 auth-port 1645 acct-port 1646
aaa authentication login method_GRP-DOT1x group GRP-DOT1x
radius-server host 192.168.1.3 auth-port 1645 acct-port 1646 key 7 00xxxxx
wlccp authentication-server client eap method_GRP-DOT1x
ssid vlanfordot1x
On the infrastructure AP:
dot11 ssid vlanfordot1x
vlan 10
authentication open eap method_GRP-DOT1x
authentication network-eap method_GRP-DOT1x
interface Dot11Radio0
ssid vlanfordot1x
encryption vlan 10 mode wep mandatory
nutchaporn Wed, 07/09/2008 - 18:58
Hi, I have found this
Note By default, the access point sends reauthentication requests to the authentication server with the service-type attribute set to authenticate-only. However, some Microsoft IAS servers do not support the authenticate-only service-type attribute. Changing the service-type attribute to login-only ensures that Microsoft IAS servers recognize reauthentication requests from the access point. Use the dot11 aaa authentication attributes service-type login-only global configuration command to set the service-type attribute in reauthentication requests to login-on
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_3g_JA/configuration/guide/s43auth.html
SERGEY KAIDAN Wed, 06/09/2010 - 00:07
I use:
no ip address
ip access-group 100 in
no ip route-cache
encryption mode ciphers tkip
encryption vlan 210 mode ciphers aes-ccm  (important feature)
will it work if  I config WDS with IAS as I can see above ?
Trending Topics - Security & Network
