LMS 2.6 monitor stack member,topology map, colored syslog messages
Answered Question
Jul 4th, 2008
  • Bronze, 100 points or more
I'm using LMS2.6 with the default versions of other modules at one customer location, he need to implement the following issues, and I'm struck here.
I need to know whether we can view syslog messages in RME in color depending on the severity. Like Alert in red,error in brown..etc..
How do I know from ciscoworks when a switch in a stack is down/rebooted. Can I monitor the stack in realtime with some image..so that I can know when one stack memeber down.
In CM I have to make one base topology diagram showing main sites, when I click on the site, it should show me the devices under that site. Is it possible to do this?
Pls..guide me in this regard.
Correct Answer by Joe Clarke about 8 years 8 months ago
I do not believe Cisco Monitor Manager will provide a per-member stack view. It does, however, provide a topology map that shows fault information. CMM does not integrate with LMS, and is typically deployed to smaller organizations without any other NMS solution.
Overall Rating: 4.3 (3 ratings)
Joe Clarke Fri, 07/04/2008 - 22:24
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Syslog messages cannot be colorized in RME.
DFM can process traps from the CISCO-STACKWISE-MIB. Therefore, if your stacks are sending traps to DFM, you will get alerts in the DFM Alerts and Activities Display when a stack member goes down. The command you must have enabled on your switch to generate the STACKWISE traps is:
snmp-server enable traps stackwise
Campus Manager supports hierarchical views, but not from the Topology Map. If you create a Topology Group in Campus Manager, you will be able to display that view, but you will not be able to drill down from a parent view to its child. The one exception is with Switch Clouds. On the LAN Edge View, each group of connected switches will appear as a Switch Cloud. If you display the entire LAN Edge View, you will be able to drill into the clouds.
You can still create Topology Views such as:
Base Topology
---Site 1
------Building 1
---Site 2
------Building 1
You will be able to display each view by right-clicking on it from the main Topology Services window.
aijaz802 Fri, 07/04/2008 - 22:30
Hi Clarke,
Thanks for the fast reply as usual.
Do I need to install CISCO-STACKWISE-MIB.oid in NMS or it will be there by default?
Joe Clarke Fri, 07/04/2008 - 23:12
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
DFM has all the instrumentation built in already.
aijaz802 Fri, 07/04/2008 - 23:18
Thanks for the reply..
Is any other cisco mgmt s/w has ability to monitor stack memeber status graphically in realtime? Like it should represent 5 switches of a stack in graphical along with connections, if one member switch goes down, it should alert in realtime to the monitoring team.
I read about Cisco monitor manager, does this support. Can I integrate it with CiscoWorks LMS? Should be installed standalone.
Correct Answer
Joe Clarke Sat, 07/05/2008 - 09:21
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
aijaz802 Sat, 07/05/2008 - 22:36
Thanks...for the response..
