876 IOS question
Jul 5th, 2008
Well i got my hands on a 876 router that my company had purchase 2-3 yrs ago.
The router has the 12.4(4)T3 IOS and the c870:adventerprisek9-mz.124-4.T3.bin system image.
So my question is : Is there any newer IOS that i can install in this router ??? i want to reset the router's config so i can use to for a site-to-site vpn with i Cisco ASA 5510 (since some time ago it had being used as adsl modem for a SOHO)
a.alekseev Sat, 07/05/2008 - 00:50
  • Gold, 750 points or more
the latest is c870-adventerprisek9-mz.124-15.T5.bin
John_Kapi Sat, 07/05/2008 - 00:57
Ok now i have 1 more question, should i contact the Cisco resseler company that provides us with cisco gear to give me the new IOS because i don't think i have permission to download it from here.
Thanks for your replay a.alekseev
really appreciated !
Richard Burts Sat, 07/05/2008 - 06:25
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Ioannis
To start with the obvious question - is this router covered under a maintenance contract? If so you should be able to get an update to the IOS. If it is not covered under a maintenance contract then yes you should contact the reseller and ask them about getting a newer version of IOS.
Rick
John_Kapi Sat, 07/05/2008 - 08:50
Either way i dont have access to dowload it.
I believe all our gear has maintenance contract and an expensive one too !
Richard Burts Sat, 07/05/2008 - 12:32
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Ioannis
If the router is covered by a maintenance contract then whoever issues and manages the maintenance contract should be able to get a code update for you.
Rick
