PSTN Phone disconnects after on-hold for 25 seconds
Answered Question
Jul 5th, 2008
Hi all,
My PSTN phone disconnects after 25 seconds when I put it on hold from my MGCP branch router.
I don't know what other information to provide here. Please ask questions.
Thanks in advance for helping out.
Correct Answer by rob.huffman about 8 years 3 months ago
Hi Shailendra,
Please try the following command on your gateway.
no mgcp timer receive-rtcp
From this good doc;
Hope this helps!
Overall Rating: 5 (1 ratings)
Ayodeji oladipo... Sat, 07/05/2008 - 05:01
what do you mean by your pstn phone..?? Do you mean a call to the pstn or a call from the pstn..if this is it then do the following..
on your router turn on debugging..type the following in privilige mode...
debug isdn q931
term mon
place a test call and send the output of the debug
ShailendraK Sun, 07/06/2008 - 06:15
Hi thanks for taking the time to reply,
The call in or out to the PSTN was having the same problem.
The issue is resolved by the foll command:
as suggested by Rob.
