PRI Channels on CME
Jul 5th, 2008
Hi, if I am setting up an ISDN30 PRI on CME in the UK (BT) and we have purchased 6 channels, does the D channel need to be included in the config i.e.
pri-group timeslots 1-7
Thanks.
Ayodeji Okanlawon Sat, 07/05/2008 - 05:17
  • Cisco Designated VIP,
    2017 IP Telephony
If you have purchased 6 channels, then you can only have 6 bearer channels...The D channel cant be included in your pri timeslots
your config will be pri-group timeslots 1-6
