Problem with an ASA.
Answered Question
Jul 5th, 2008
I have an ASA and I'm trying to implement something like “load sharing” between 2 ISP's.
I tried to do “dual ISP”, but that's not what I intended to have…
I tried to implement “favoring static routes based on reachability”, but I did not succeed.
Somehow this last implementation is, I think, very near of what I need. The problem with this is that it has a limitation… it doesn't let me put 2 default routes pointing to 2 different interfaces (I mean, putting the traffic that leaves the ASA in 2 different interfaces), like this:
route outside 1 track 1
route dmz3 1 track 2
Can some one help me?
Thanks in advance,
Correct Answer by a.alekseev about 8 years 3 months ago
ASA cannot do loadbalancing like a router.
You cannot have two active defalt routes. Only one will be active.
for redundancy you can use the following
Overall Rating: 5 (1 ratings)
rcapao Fri, 08/22/2008 - 13:32
when you said "load balanced" you minted to say "load share", wasn't it so?
Rui Capao
